Ariston AFA 250 Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ariston AFA 250 Dishwasher
  • #23641
    cador
    Christmas problems…. My dishwasher starts for about 10 secs, then the initial rinse light (1st one on the left as you look at it) starts to flash and the pump noise (I think that is what it is) stops. It has happened before and after leaving it for a few days it corrects itself for a few more weeks. Any ideas?
    #198910
    Re: Ariston AFA 250 Dishwasher
    Possible overflow into base. Pull the machine forwards, place a few towels on the floor then tilt it back or to the side. If you get water running out from underneath this confirms an overflow or leak. Using 3 in 1 or 4 in 1 tablets can cause this. Fairy Active Bursts with salt if your water is on the hard side should help. You may also have an internal leak, if the fault returns fairly quickly this needs investigating and repairing. Plug out at all times when working on the machine, if you need help then try the link below to see if we have someone who can be of assistance.
