Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Ariston AFA350 Pump sticks on / flashing light
- This topic has 4 replies, 2 voices, and was last updated 20 years, 5 months ago by
sean250.
November 5, 2005 at 9:51 am #13067
sean250
ParticipantHi all.
As the title says I have an Ariston AFA350 dishwasher.
Here are the symptoms:
Sometimes washes fine and then instead of finishing the cycle goes back to the intial light which starts to flash instead of the last light (usual indication of end cycle) Manual says consult engineer no further help.
Also the drainage pump continues to run………….until you turn machine off. Reseting and switching back on; the pump fires up again even with the swith left at reset. Turning to a cycle has zero effect.
What I have tried:
Checked pump not blocked by manually filling machine with water and checking it drains. Once wwater drains pump continues to pump air (suspect this is bad for the pump)
Taken off front door panel and examind simple rotary switch. But all back together and made one cycle of wash but pump remained on at the end.
Now suspect the control board but before I spend £50 on one I wanted to see if there was any kind of switch at the pump or if the control board did it all.
Ideas?
Thanks in advance
SeanNovember 5, 2005 at 10:51 am #152937Dave_Conway
ParticipantRe: Ariston AFA350 Pump sticks on / flashing light
Normally a continuous pump indicates a flooded base, possibly caused by an internal leak. The flood protection system has been activated i think.
Try leaning the dishwasher forward or backward and see if any water runs out (towells handy ;)).
This of course is not the cure but it rules out a few things 🙂
You may need an engineer to sort the root problem for you, check Repairs@ for one.
Power off when investigating please :zap:
November 5, 2005 at 12:05 pm #152938sean250
Excellent.
I tipped it forward an a syrupy kind of water came out.
I reset the washer and all fine. Well done!
Much appreciated. At least I can tell them what to fix when they arrive (that really annoys them lol 😉 )
November 5, 2005 at 12:25 pm #152939Dave_Conway
By “them”, do you mean appliance engineer ?
I’m one of “them” 😉
November 5, 2005 at 2:28 pm #152940sean250
yes…………..but only in a nice way. I just know how annoying I can be when anyone comes to fix stuff, being an engineer myself 😆
