Ariston AFA350X – sporadic single beep
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ariston AFA350X – sporadic single beep
  • #38639
    lineb
    A while ago I had a problem whch turned out to be a blocked pump – not long after resolving this problem the machine, although working fine, started emitting a single beep at unequal intervals during the wash cycle. As I say m/c seems to be working fine apart from this annoying beep. I’m assuming an intermittent fault causes the single beep as it isn’t at regular intervals. No leds flash to indicate a particular fault — any ideas / suggestions appreciated.
    #259509
    Re: Ariston AFA350X – sporadic single beep
    This is an almost impossible question to answer…. These machines are prone to random earth leaks – heater specifically; dribbles of water almost constantly into the base and dodgy electronics. Any or all could cause this problem.
