Having just moved house, I have mislaid the manual and cannot get the machine to work. It seems to initiate cycle, then the “F-08” fault message appears and everything stops.
Is there anywhere I can get another manual? Or is this a simple fix? I should stress I am not the least bit technically minded!
It relates to a ‘Heating’ fault (either the Heater or the Control Module are at fault) This requires expert attention through a local independent repairer, check for one in your area via this link: Repairs@
Copies of User Instruction Booklets are available by telephoning Ariston (cost = £11 each) 🙁
