Ariston AIB14UK fault code F10
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston AIB14UK fault code F10
  • #9008
    Hi – Does anyone know the meaning of fault code F10 on a Ariston AIB14UK please?
    #131603
    Re: Ariston AIB14UK fault code F10
    Water level control problem Henry. The system may be blocked at the bottom, the air hose may be holed or not sealing properly, or the switch itself may be defective. It CAN be the computer board, but check the rest first.
    Pull the plug before doing anything………. :plug:
    NickyName
    Hi – thanks for that – I will check it out
