Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston AL14 – Fill problems
- This topic has 5 replies, 3 voices, and was last updated 18 years, 11 months ago by
Lemole.
April 25, 2007 at 2:06 pm #26879
Lemole
ParticipantMachine starts to fill with a very small amount of cold water, hot seemingly not being taken in at all as powder remains in the drawer. Machine then sits and does nothing. If I manually fill with cold water, carefully via the powder drawer then it works and washes fine when the water drains away then I manually refill it through the rinse cycle too.
I replaced the Hot solenoid intake valve, there appears to be connections from the cold solenoid valve to the hot. If I stop and reset the machine there seems to be 3 short blips on the front LED. I’ve checked the pressure tube and it seems to be fine, the pressure bottle is clean and clear. I did have it on its side about three or four weeks ago as it was the only way to access the pump to get the filter out as it was jammed in solid.
Any Ideas on where to look at next. There is no change to the amount of water intake if I alter the programmes or alter the temperature settings.
April 25, 2007 at 11:21 pm #211735Penguin45
ParticipantRe: Ariston AL14 – Fill problems
Using your multimeter and with the power off, split the circuit to each of the valve solenoid coils and take the reading – you should get 3-4kOhms across each. The coils are linked by a common neutral, each has an individual live supply.
Penguin45.April 26, 2007 at 7:46 am #211736Lemole
Thanks Penguin45, I shall test the solenoids tonight. With the power off I assume I just take the spade connectors off each of the solenoids (2 on the cold and 1 on the hot) and put the Multimeter over the contacts and note the resistance which should be between 3 and 4 ohms?
Assuming there is no problem with the Hot as it is new, could a failure of one of the cold inlet solenoids cause this filling problem? I have spent time watching the machine go through its cycles. The cold water starts to run in for around 30 to 40 seconds, pressure on both hot and cold is good, no kinks in inlet pipes etc….powder remains in the tray. I have to manually fill to get the machine to start turning but once I have done that it seems to work fine until it needs filling for the rinsing cycles. Interestingly on the very last rinse cycle, cold water runs in to the correct level. I’ll post my findings as soon as I have them this evening but wanted to check my testing method and ask the above.
Many thanks for your assistance
LemoleApril 26, 2007 at 7:34 pm #211737Lemole
Tried the multimeter test this evening, removed the spade connectors just to make sure and tested each seperate solenoid with the results as follows:
Hot Inlet Solenoid Valve reading 3.48 kOhms
Cold Inlet Solenoid Valve No1 (nearest back of machine) – No Reading
Cold Inlet Solenoid Valve No2 Reading 1.92 kOhms
So, putting 2 and 2 together do you think this means that I will have to replace the Cold water solenoid valve? Don’t wish to throw good money after bad to replace this cold valve if it is not the definitive source of the problem. Machine is starting to get a bit noisy but it has given good service for 6 years and i’m reluctant to part with it if it is still servicable.
Many thanks for all assistance.
LemoleApril 26, 2007 at 7:51 pm #211738hotpnt
yes, that valve will be the problem, it will fill on the last rinse because it uses the other cold valve to wash in the conditioner. easy fix.
April 27, 2007 at 12:14 am #211739Penguin45
If you contact spares@ukwhitegoods.co.uk and ask for a C00066518 inlet valve, they’ll be able to supply a replacement for you promptly.
Penguin45. -
