Trying to fix for a friend. Previously it delayed starting for no reason and later had to be switched off to stop spinning. Now no power and no functions, No problem with the socket or plug and I’ve had a quick ‘poke’ around inside and found no obvious problems like loose / burnt wires etc (not sure were an internal fuse may be) except I found a broken rubber belt 5mm diameter in section and 180mm diameter overall at the back end of the machine at the bottom
Any advice would be great
I’d previously posted this on the Margherita more problems but I think the thread’s died…
