Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ariston ald12uk wash cycle goes on for over 4 hours
- This topic has 10 replies, 4 voices, and was last updated 13 years, 5 months ago by
slyp98.
November 2, 2012 at 11:30 pm #72317
slyp98
Participantoldie this , washer dryer all cycles takes hours to complete customer sayes clothes coming out not cleaned properly , checked element it is heating the water fine any suggestions please thx
November 3, 2012 at 2:45 am #384179bryan-206
ParticipantRe: ariston ald12uk wash cycle goes on for over 4 hours
Blocked? Or poor water pressure?
November 3, 2012 at 11:08 am #384180slyp98
its filling with water fine 1 min , pressure switch cuts in and starts tumbling ?
November 3, 2012 at 11:37 am #384181bryan-206
How long does it take to drain full to empty…..?
November 3, 2012 at 11:50 am #384182slyp98
normal times 40 or 50 seconds
November 3, 2012 at 9:08 pm #384183bryan-206
Then so long as motor and heater work. Fill and drain times are ok. Only really leaves the module….
November 3, 2012 at 10:02 pm #384184slyp98
looks like it mate
November 3, 2012 at 10:39 pm #384185madangler1
Is it actually finishing the cycle with out intervention ?, if its taking longer but finishing do you know what part of the wash is taking the longest.
The way these work is they basically split each part of the wash into tasks and won’t move on or can add time to a specific part should it believe it has not completed what it needs to do
It like a mechanical timer and won’t move on until its ready.
Its unlikely to add time to every part of the wash, it got to be a specific part. Normally it’s heating that adds the most time, often hours. If the heater is good what about the NTC, of it believes its cold then I will just keep adding time.
Also have you done an IR check, seen low IR cause strange stuff as well.
November 8, 2012 at 7:56 am #384186martinm
Or is it possibly syphoning sometimes on rinses, i.e. too much waste hose pushed into standpipe?
November 19, 2012 at 9:26 pm #384187slyp98
does anyone know what the resistance of the wash ntc on these is thanks
January 17, 2013 at 1:45 pm #384188slyp98
ok so customer is back on again , comes to the end of a programne and just starts another one . also only 220v going to element nothing coming out ie no voltage across it , pcb im afraid
