Ariston as 100
Viewing 3 posts - 16 through 18 (of 18 total)
  • #184016
    gegsy
    Re: Ariston as 100
    Diy-Jim wrote:Greg, this was a solution back in nov 2005 by iandms, and you said then that you had known a timer cause lack of heating…I guess you must have forgotten.
    I guess so 😀 at least you must have found the “search” facilty though 8)
    Diy-Jim
    So to sum up, the washer would stall at two points and need advancing by hand, and the wash would be poor because the water wasn’t being heated.
    the element was ok, the thrmostats were ok. the problem was the Copreci mechanical timer was sticking or having a poor contact on the heater circuit. this was cured by spraying and rotating as above. The machine runs the full cycle now because the water is heated.
    diy-jim
    #184018
    Diy-Jim
    Re: Ariston as 100
    The search is great when you know what to look for Greg. After checking out the thermostats I was looking to buy a new timer, and came across the name Copreci, which I then tried in the search, and if iandms hadn’t mistakenly thought his timer was a Copreci…
    Anyway the wife’s dead chuffed:
    so I don’t have to turn the knob any more?
    No
    and it heats it enough to dry the dishes?
    Yep.
    O
