Ariston AS100 dishwasher leaking
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ariston AS100 dishwasher leaking
  • #7329
    I’m having a problem with my Ariston AS100 Advantage dishwasher, serial number 201287848 (I think). It’s a compact (if that’s the right word – ie not a fullsize washer), was bought in August 2002 and has worked fine until now. The salt & rinse aid are regularly topped up.
    But it has suddenly started leaking from the hinges on both sides. In other words when looking at it straight on, foam emerges from the bottom left and bottom right hand corners of the door. It happens quite early in the cycle, approximately 15 minutes in (though I’m not totally sure of the timing). The first time I wasn’t there and came back to find the patches on the floor. It wasn’t loads, they were both about the size of a person’s foot. The next time it happened I saw the leaking as soon as it started and switched the washer off.
    There are no obvious faults like broken seals, but I’m a definite layman. There’s a bit of gunk, which I’ve now cleaned away, but could a proper washout of the whole thing, filters etc possibly clear this problem up? Or does it sound more serious, possibly requiring an engineer… or new appliance? I’d very much like to avoid the latter, at least.
    Any help much appreciated!
    #122742
    Jakester you mention foam there, is it actually foam you’re getting as there shouldn’t be any foam? The detergents used do not foam as that would cause issues with all sorts.
    Re: Ariston AS100 dishwasher leaking
    Hmm, yes, there was definitely foam. I’m using tablets and am pretty sure I’m halfway through a box, so would’ve thought if they were the wrong type I’d have noticed before now. But this is obviously the first thing to check before thinking about engineers so thanks very much, your advice is much appreicated.
    #122744
    cookerfix
    Hi jakester
    Using 3 in 1 tablets will cause overfoaming in 6 place setting dishwashers due to excess dosage of rinseaid in the tabs.
    Regards
    Mal
    #122745
    Thanks Mal, that could well be it, as I’ve just remembered the foaming coincided with a re-fill of the rinse aid. Obviously I can see that using 3-in-1 tabs (which we may well have grabbed off the supermarket shelf by mistake) at the same time as a full rinse aid reservoir could cause problems.
