Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Ariston as100 help
- This topic has 6 replies, 4 voices, and was last updated 19 years, 7 months ago by
denviks.
September 8, 2006 at 6:50 pm #20697
denviks
Participanthi all.i know this is a bit cheeky as its my first post on the site. i really need help with our ariston as100. today i turned the dishwasher on , over 2 hours later i noticed that the dial had stopped……i can hear a pump going all the time…………
so thinking that the dial might have been stuck i clicked it forwards.but the pump still remained on….. infact you can turn the dial all the way around and the pump stays on…. also the dishwasher is very dry inside so i would guess that it stopped it cycle before the main wash but after the rinse,,,,…… what would make the pump run all the time??
can anyone help as its a brilliant dishwasher and i dont want to loose it if i dont have to…..many thanks in advanceden
September 8, 2006 at 7:02 pm #188074Penguin45
ParticipantRe: Ariston as100 help
The flood protection is activated – it will over-ride any timer setting. Drain the undertray and the system will re-set. However, if you don’t find the leak, it’ll trip again……..
Power off, before going inside.
Penguin45.September 8, 2006 at 8:38 pm #188075denviks
hi and many many thanks for your reply.now that does make complete scence. sorry if i seem a bit slow on the uptake but how do i drain the undertray…………. i will make sure the power is off before doing anything……….
many thanks againden
September 8, 2006 at 9:29 pm #188076Dave_Conway
denviks wrote: how do i drain the undertray
Lean the dishwasher to one side and get some towels ready 😀
If it happens again there’s an underlying cause (leak as mentioned) that will need checking out.
September 8, 2006 at 10:34 pm #188077denviks
thanks guys ….i will give it ago in the morning………do i need to disconet the drain hose……………. looking forward to a wet kitchen floor already 😆 😆 😆
September 9, 2006 at 10:05 am #188078Diy-Jim
Denviks.
I only know this because my as 100 has a fault that I have yet to cure. It does sound like the flood protection as activated. This is just a polystyrene float in a depression on the very bottom of the machine- the metal tray just above the floor. When water collects in this depression, it lifts the float, which clicks a micro switch.
To get the float to drop, you need to empty out this water, by leaning the machine to one side, the water will be on the floor and the switch will re-set.
If it doesn’t the float may have jammed- mine was covered with brown gunk. Cleaning this should sort it.Don’t forget though that the water has leaked from somewhere in the machine. An unusual circumstance may have caused it to collect there this time, and the problem may not occur. If it does, you need to find the leak.
You must disconnect from power, but you don’t need to disconnect the hose or outlet – these contain water that hasn’t leaked – it’s still in the system. You are emptying water that has leaked into the inside of the dishwasher.
If it makes it easier, you can disconnect them.
Hope this is some use.
They’re brilliant when they’re working
Diy-jimSeptember 9, 2006 at 4:18 pm #188079denviks
thanks all……………..
you have all been a massive help.just an update for you..i unpluged the machine and put towels under it.tipped it to the left and loads of water came out. 😯 …… so i left it for 10 mins and did the same but no more came out.i have just turned it on and its working again.i will run it through a cycle and see what happens …..i will let you know the result
many thanks again for your help guys 😉
