Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston AVL 120 working out error code..
- This topic has 6 replies, 2 voices, and was last updated 14 years, 2 months ago by
polarity.
January 24, 2012 at 11:11 pm #67560
polarity
ParticipantHi
I have a French Ariston AVL 120 – this seems to have many guises (looks like AVL 109 and others) but I cant seem to find the UK equivalent or underlying Indesit/Hotpoint machine.Anyway it sometimes stops just before the spin section, – rapid flashing key light and the bottom 2 of the 4 buttons left of the key button are flashing. The 4 buttons are Timer, Super wash, easy iron, quick wash (excuse rusty French!) – last 2 are flashing. I searched on here but the info I found refers only to 5 buttons.
Thanks for your help!
January 27, 2012 at 8:38 pm #367787polarity
ParticipantRe: Ariston AVL 120 working out error code..
Anyone? I did read all the help files first!
It looks like this: http://www.recupe.fr/adpics/a-donner-ma … er-698.jpg if that helps.Thanks!
January 27, 2012 at 10:44 pm #367788iadom
ModeratorRe: Ariston AVL 120 working out error code..
There is only one model of this Indesit junk sold in the UK as far as I can see.
Error codes are shown by flashing a combination of the bottom, left hand indicator light and the four right hand column of buttons/lights.
Possibly F03..
NTC short/open circuit: check thermistor & module
connections.January 29, 2012 at 7:21 pm #367789polarity
Thanks, the bottom 2 of the right hand column are flashing making 24 – but the list here http://www.ukwhitegoods.co.uk/help/fix- … codes.html only goes to 16 ?
January 29, 2012 at 10:15 pm #367790iadom
Those are totally different machines and error codes, you do have F03.
January 30, 2012 at 10:58 pm #367791polarity
Great, thanks, I will check it out – though if it was the thermistor I would expect to see the abort happen on the fill/heat cycle rather than the empty before spin ?
Oh and re the piece of junk,
a) it was bought before I discovered this forum
b) I did just buy a SEBO vacuum since I discovered this forum (and yes it is a seriously quality piece of kit!)January 31, 2012 at 9:07 am #367792iadom
The error codes are only a rough guide, with the electronics on these anything is possible. :rolls:
