Do you mean an Ariston AVL147, which two neons are flashing ?
Doubtful if you need to reset the computer. It sounds as though you have a pump or sump hose blockage, or failed pump, more likely to be the former due to the age of the machine.
Not the easiest pump to access, follow the grey plastic hose to locate pump. Please remove the plug at all times.
