Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston AVXXL109EX Programm Error
- This topic has 9 replies, 3 voices, and was last updated 15 years, 11 months ago by
b-52.
May 25, 2010 at 11:22 pm #54826
b-52
ParticipantAfter i have replace the bearings i have a strange problem ,the washing machine starts ,takes water for 10 seconds then stops for 5 seconds and then stops again it stays in sleep and some times start after 5 minutes or not starts and the power light flashing with option buttons 2,3,4.After that if i reset it from the button and start again nothing happens..no water nothing hmmm.I take it off the power line then back on again and starts the same.
I change the water sensor but i think the old one is ok.Is this a main pcb error?program error?do i have to make any adjustment to water sensor?
Now at the end of the program it does not off the status leds or the option button led i had select.
Any Help Please ?…THANKSp.s:Is there a way to reset it to factory defaults?
May 26, 2010 at 10:26 am #321088iadom
ModeratorRe: Ariston AVXXL109EX Programm Error
No factory reset option.
Lights 2,3 & 4 is fault code F07. Heater relay fault.
You should never attempt to adjust the water level switch.
Did you remove the main PCB when you changed the bearings?
It could be caused by loose or dirty connections on the main PCB. You need to check all of the connectors and tighten up the plugs by giving them a gentle squeeze.
Also need to check the wiring to the NTC slotted into the heater plate for bad contacts.
Did you buy that machine in Greece, it is recognised on the UK parts software. 😕
May 26, 2010 at 5:09 pm #321089b-52
ParticipantRe: Ariston AVXXL109EX Programm Error
I didnt adjust the water sensor.
I will disassemble it again to check the connections.
No i didnt remove the main PCB when i change bearings.
The option buttons are at the left of the contol panel and i count them from the top to the bottom,is that correct?
The strange is that if it takes water is for 5 seconds then stops then the second led from the left in status leds flash and nothing happens.After 5 minutes takes water again until the water sensor reach the pressure then the program start ,i think that it does not take the water at the correct time.
Thanks for the reply!ps:Yes is a Greek model
May 26, 2010 at 7:02 pm #321090iadom
Left hand buttons from top to bottom is correct.
When you say the second light from left, is that the prewash light?
That usually flashes due to no water supply, what is your water pressure like?
If you have a megger or multimeter you could check the fill valves electrically.
May 26, 2010 at 7:26 pm #321091b-52
Yes that is the status led.
The valves are working because if it pass that step all the program works ok.If there was a problem with the valves the problem will exist to the rest of the program.or not?
At the start i hear the valve is opening then after 5 seconds i hear it closes after 5 seconds to 10 it opens again then closes then prewash led flash.
The water pressure is ok ,that was the place it works before the repair.May 26, 2010 at 9:52 pm #321092iadom
I am hoping that you will have taken the time to have a read of the forums.
If you have you will by now have realised that Indesit group products are though of as bottom end, low quality, budget machines here in the UK.
What you have is a Hotpoint shell and drum assembly with Indesit electronics in it. These are without doubt some of the worst, most unreliable electronics on the current market.
The error codes are only a guide, it is not unknown for the error message to bear no relation to the actual fault.
You don’t even need to have touched the machine for the electronics to fail, just a change in the wind is all it needs. :rolls:
Apart from checking all of the wiring connections and doing an insulation test on all components there is little more advice I can give you, aside from the obvious that is. 😉
May 27, 2010 at 8:54 pm #321093b-52
I final manage to make it work.The problem was-as you say- the connection to NTC ,the wires are lose from the connector pins.
I want to say a big THANKS for your help!! 😀
May 28, 2010 at 9:41 am #321094iadom
Does that mean I get a free holiday in Greece now? 8)
May 28, 2010 at 1:13 pm #321095don
iadom wrote:Does that mean I get a free holiday in Greece now? 8)
Can you bring me back some Metaxa7 or 12 star please Jim 😆May 30, 2010 at 8:33 pm #321096b-52
Yes and i will buy you a barrel of ouzo!! 😯 you will forgot even your name xeexexexe
