ariston awd 12 s fault code 10
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ariston awd 12 s fault code 10
  • #37190
    linw
    Hi hope someone can help..machine stopped working and control dial started rotating.light flashes 10 times any ideas
    #253820
    helo_75
    yup.. pcb failing to sense pressure switch
    pressure switch not expensive… its normally the pcb, which would require an eprom, more expensive
    hope this helps
    #253821
    linw
    Re: ariston awd 12 s fault code 10
    Thanks for your quick response. in your expierience would it be worth
    replacing the pressure switch or just call the engineer out
    #253822
    helo_75
    personally, id go buy a proper machine
    harsh though it may sound, these machines are very very unreliable
    thing is , its nearly always the board, and as we’ve been discussing the pcb problem, and recently, indesit have changed them , and a lot of engineers arent geared up
    its getting more complicated tbh
    its your call,although indesit do do fixed price repairs at £89 including all parts and labour, regardless of whats wrong, as long as your machines under 5yrs old, £99 if its over 5yrs old
    certainly your cheapest option, but for me, id be looking at other options, such as anything other than hotpoint/indesit
    hope this helps
    #253823
    linw
    Thanks Helo, very useful advice
