Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston AWD12
- This topic has 16 replies, 4 voices, and was last updated 16 years, 11 months ago by
criss5555.
May 2, 2009 at 8:32 pm #45421
criss5555
ParticipantHi, I have just fitted a new module board and upon the first trial run the machine now fills with water and the pump pumps it out, the dial rotates and I get 3 flashes. Any advice welcome and appreciated. Chris
May 2, 2009 at 8:53 pm #285622helo_75
Participantgrrr, 2 threads isnt good
its not sensing the ntc.. which is the temperature sensor on the rear of the tub
it might be worth chicking the connections on the pcb/ntc
keep it to one post please, it avoids confusion
May 2, 2009 at 9:05 pm #285623criss5555
ParticipantRe: Ariston AWD12
Hi, sorry about threads its my first time and I put the first one in the wrong forum. Thanks for your help I’ll give it a go. Cheers Chris
May 3, 2009 at 10:38 am #285624criss5555
Hi again, I checked all conections to module board and I’m pretty sure there OK but the problem remains the same. If I set the dial to the reset dot I get a slow flashing light then after about 10 seconds it starts to fill with water and at the same time the pump starts to empty the water, then the dial begins to click round with the 3 flash code. Is there any other thing I could check or replace. Thanks again, Chris
May 3, 2009 at 10:52 am #285625helo_75
Participantwhere did yu get the pcb from?
May 3, 2009 at 11:02 am #285626criss5555
Hi, I bought it online from the ariston parts site. unfortunatly. I had’nt found your site at the time. Hope this does’nt disqualify me from receiving help. The machine is about 5 years old but has had little use as it is fitted in a american motorhome. I would not bother and buy a new one but to get it out means removing a window ect. quite a big job and I’d need about four strong men. Hope to hear from you again. Thanks Chris
May 3, 2009 at 4:56 pm #285627helo_75
Participantahem……
did you program it with a smart card or eprom?
i bet you didnt
May 3, 2009 at 4:57 pm #285628helo_75
Participantdidnt they bother to tell you that the board doesnt actually come programmed.. if they didnt thats more than a little naughty
May 4, 2009 at 10:04 am #285629criss5555
ParticipantHi, No they did’nt tell me I needed to programe the board. I notice this site does not sell an eprom, I can buy one from the ariston site for 33.99. Can you give me any advice about what to do once I’ve got it. I’m a retired engineer but electrics was never my strong point, changing a board with a few plugs and hey presto seemed the easy option, I am now determined to fix this bl****** machine if it’s the last thing I do. Thanks for your help to date. Regards Chris
May 5, 2009 at 6:38 pm #285630helo_75
Participantif its a later board, then you cant fit an eprom.. itll have a blank one installed…. there WILL have been a big sticker on the box warning you to program it using a smart card
for me, id contact tony at http://www.emwelec.co.uk/
he will be very helpful.. he could program the board youve got, or he could send you an exchange pcb overnight
unless your prepared to spend £60+vat for a reader and £20 +vat for a card, you dont really have another option im afraid
sorry
May 5, 2009 at 7:42 pm #285631criss5555
ParticipantHi, thanks for that lead I’ll give them a ring tomorrow and hopefully they’ll be able to sort things out. All thats on the box is a sicker saying module no eeprom. Thanks again I’ll let you know how I get on. Cheers Chris
May 14, 2009 at 9:43 am #285632criss5555
ParticipantHi, Tony at EMW sorted the board out and machine is now up and running. Thanks for all your help I could not have fixed it without you and this wonderfull site. Best regards, Chris
May 18, 2009 at 5:44 pm #285633IrishVillian79
I’m having an issue with my washer dryer where it automatically goes to the dryer after the short cycle (cycle 8) finishes. The timer is set to 0 at the time yet it continues to go to the dryer,
Any help on this would be appreciated.
NiallMay 18, 2009 at 8:44 pm #285634Penguin45
Plug falling of dryer selector can cause this. Power off before removing lid.
May 19, 2009 at 6:56 pm #285635IrishVillian79
Apologies, but not sure what you mean by “Plug Falling” 😯
A basic explanation would be much appreciated
regardsNiall
