Yes the clicking dial problem again – sorry but I have searched the forum for the solution to my problem non seem to specifically fit.
Last week had a pump blockage – half a pencil and couple of coins; drained machine cleared pump and all seemed well
Today blockage – guess what the other half of the pencil
Now the machine still won’t drain control dial clicks around when required to do so.
Removed the pump and checked again rubber hose from bottom of drum to pump is clear as is the outlet hose from the pump – some water does seem to get pumped out when trying a short wash cycle – but still not full draining.
Pump impeller turns as normal and as described in other posts as being normal – nothing wrapped around the spindle.
Need to check the pump motor resistance (but it’s now 02:40 in the morning and I’m in the same condition as the machine – knackered)
I believe it should be around 146 ohms?
Any help appreciated.
