Ariston AWD12 Help!
  • #28049
    gsmith
    My Ariston AWD12 Washer drier has developed the following fault;
    When you set a programme the LED flashes to show it has accepted the instruction the light then stays on, the door locks and then nothing.
    I have taken the kick board off any checked the chamber it seems to be clear.
    The machine is about 2 years old and we hate it!! Constant resetting etc…so if a repair is going to be expensive I think a new machine will be on the books ….Not Ariston!!
    Can anyone help with this problem, any advice would be greatly received.
    #216662
    Re: Ariston AWD12 Help!
    This will be a problem with the computer board, almost dead cert. And yes, it would be expensive.
    Much better machines out there……….
    gsmith
    Thanks for the quick response Penguin.
    My wife has just told me that she manged to get it through a complete cycle after the fault started then the fault came back.
    Could this mean there might be a lose wire somewhere or am I just clutching at straws!!
    #216664
    hotpnt
    hi, i would think if the light is on, door is locked but no fill, the motor brushes are probably shot
    #216665
    Jacko100
    Hello – I have an Ariston awd12S with similar fault and would be interested if the fault in this thread was ever resolved ?
    My machine “sometimes” starts filling water if I am lucky… sometimes I have to “flick” the on/off button a couple of times and it starts filling.
    Then it stops filling and just sits there !
    ALthough I noticed that if I leave it long enough (seemed like 30 minutes but was probably only a few) – it pumps out the water, the dial turns and I get 2 flashes from the fault led.
    I notice that if I set the dial to the “empty drum” setting and power it up, it goes through that cycle and empties ok.
    BUt I have not seen the drum move at all since this fault occurred, and have noticed on the forum that 2 flashes indicates “motor fault” (?) – so am hoping its a simple connection or brush replacement.
    Am fed up with this machine – had new temperature stat (TOC ?), new heater element on the drier, and new bearings and seal on the drum shaft !!
    I also notice a very faint hummm from the machine when I turn it OFF !!! which goes away when I turn it on (using the on/off button on the front that is !)
    Thanks for any advice (even advice to chuck the thing away!)
    Steve
    #216666
    Jacko100
    Hi ! Have posted another message under my last one, because I realised that I forgot to tick the box that says “notify me when a reply is posted” – so I thought I would post another message and tick the box this time !
    Probably wont get any replies now ! 😥
    #216667
    Let’s start from the position that you’re not very happy with the machine. It’s not actually very good. In fact, it’s very poor on the quality stakes. Putting ‘indesit AND electronics’ into the SEARCH facility has immense comedy value as the truth is revealed.
    However….. Check the motor brushes; info HERE. There are a few machines which last long enough to wear them out. If these are used up, a repair is a cost effective option. Anything else, I’d consider moving on.
    Stay safe, power off if you’re going in.
    ntonks
    i have 15 flashes when using program 1 or 2 and sometimes 8 but i have searched everywhere on this site and cant find anyone who has had the same fault that gives 15 flashes, if anyone can help it would be appreciated 🙂
    #216669
    F 15 is a dryer element fault, if the dryer element and stats are OK then sadly it will be more than likley that the main PCB has failed.
    ntonks
    many thanks for the reply, i imagine it is cheaper to replace the complete machine if that is the case? 🙁
    #216671
    Definitely not a cheap repair, not the best machine on the market by a long way sadly. 😥
    Worth putting a meggar/mulitimeter across the dryer element and checking the safety cut out stat first though.
    Be sure to remove the mains plug first.
