Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston AWD12 Margherita 2000 – Door not opening
- This topic has 11 replies, 4 voices, and was last updated 19 years, 1 month ago by
Darron.
March 22, 2007 at 10:28 pm #26077
Darron
ParticipantHey, water is al drained but I cant seem to get the door open, is there another way to pop open the door ? Secret latch ? Thanks in advance.
March 22, 2007 at 11:23 pm #208679iadom
ModeratorRe: Ariston AWD12 Margherita 2000 – Door not opening
If you remove the mains plug and the door does not open within a couple of minutes then your door interlock may have jammed. No easy way in, you have to physically bend the doorlock back and forwards until it either breaks or releases then replace with a new door lock. The top needs removing to access.
It could also be the door handle/latch mechanism, very weak and prone to failure on these ‘Indesit’ machines.
If you can pull the handle out then it will be the handle that has broken, if you cannot pull the handle without forcing or breaking it then the lock will have jammed.
Be sure to remove the plug before you put your hands inside.
March 23, 2007 at 12:16 am #208680Darron
ParticipantRe: Ariston AWD12 Margherita 2000 – Door not opening
Thanks, yeah, I may have caused the problem by trying (reaonably hard) to open the door when it hadn’t finished its cycle, and it seems to have left the door handle kinda ‘limp’, I can pull it out, but it just flaps about with no real ‘pull’ left in it :/
Sounds like the handle is broken ?
If I brake off the handle can I get the door open ? and replace the handle myself ? Or would I need to get a handyman in anyway ?
Thanks again. Soon I can wear clothes.
March 23, 2007 at 12:37 am #208681Penguin45
Lid off, power off – look down the inside for the lock and you may be able to see the door hook poking through. You may be able to pop the door by moving it – if not, the advice above applies.
BTW, a handyman will have no chance – a repairer from the repairs@ link below would be a far better choice.
Penguin45.March 23, 2007 at 12:23 pm #208682Darron
Thanks, how do I take the LID OFF ? what lid ? Its a front loader. Thanks again.
March 23, 2007 at 1:03 pm #208683Martin
Darron wrote:Thanks, how do I take the LID OFF ? what lid ? Its a front loader. Thanks again.
I really would rather suggest a simpler method of opening the door that doesn’t involve the very difficult ‘lid off’ approach. 😉
With a small ‘electricians screwdriver’ (I modified one by bending the very tip of it by 90 degress to form a little hook*) you can flick the male door probe slightly to the left and thus releasing the door catch….easy! 🙂
Then you need to email spares@ukwhitegoods.co.uk and ask for a C00065250 Handle Kit (white) or if its a silver handle then C00081331) 😉
Edit:
March 23, 2007 at 1:15 pm #208684Darron
Great thanks.
Whats the Male Door Probe look like ?March 23, 2007 at 2:22 pm #208685Martin
Darron wrote:Whats the Male Door Probe look like ?
March 25, 2007 at 4:03 pm #208686Darron
Sorry about this, but where might that part sit ? All I can see is this ..
[/img]March 25, 2007 at 4:12 pm #208687iadom
You will have to break off the handle, (don’t worry, it is already broken inside) to reveal the end of the latch lever or ‘Male probe’ 😯
The replacement comes with all the parts needed but doesn’t mention just how difficult it is to refit. 😥Jim.
March 25, 2007 at 6:11 pm #208688Darron
Really appreaciate all your help guys.
Last question (all going well), will I have to take the lid off or something that is super hard ? Ie: requiring me to call out an engineer anyway or is it worth a crack. So to speak 😕Thanks again.
March 25, 2007 at 6:40 pm #208689iadom
Removing the lid is dead easy but if you manage to release the latch from the front you don’t need to remove the lid, changing the latch assembly should provide you with an interesting and possibly frustrating challenge, 😉 take the door right off the hinge to make it a little easier and have a good look at where all the bits go before you start.
