Ariston AWD12 problem…
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston AWD12 problem…
  • #12087
    blue999
    Hoping someone can help please.
    We have an AWD12 which yesterday decided to lose the plot…
    Mid-cycle the dial started to spin round and round constantly with the drum not turning and full of water. It unlocked eventually and I got everything out (and a wet kitchen).
    It continues to do the same each time I switch it on now, fill up and the dial turns and turns.
    It is under warranty and an engineer is out next week but I’m wondering if there is anything I could try in the meantime.
    #147839
    Re: Ariston AWD12 problem…
    Pump filter blocked (behind front kick panel) I think you will find?
    #147840
    blue999
    Thanks Martin,
    something I could fix, being a complete novice??
    or wait for the engineer next Monday? A simple job for them to fix??
    Cheers
    #147841
    The user instruction booklet should refer to the Pump Filter and if your machine has got one behind that Kick Panel then it is designed for ‘user access’ 😉
    Take a peek why don’t you, but do please :plug: TURN THE POWER OFF FIRST :zap:
    #147842
    feelingsmart
    Did this fix your problem???
    Thanks,
    Phil
