ariston awd12 tumble dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ariston awd12 tumble dryer
  • #7830
    Any ideas? My washer/dryer had a blockage in the pump chamber which I’ve cleared. Now the wash and spin cycles work fine but if it carries on to the dryer the clothes get soaked again. There’s no flashing lights and the knob doesn’t click around. Help! 🙁
    #125358
    Re: ariston awd12 tumble dryer
    Presumedly the dryer control is switched off is it?
    This happens when it’s set to go to tumble when the spin cycle finishes- the dryer control is on.
    Paul
    #125360
    Sorry Paul, I missunderstood your post 😕 So your problem is that you set it to Tumble Dry and the clothes get wetter then eh? Soaking wet, would mean a pump/drain out problem, warm and damp would indicate a condenser system failure (inlet nozzle or blocked condenser).
    Hope that helps, I would suggest getting in expert help if any of the above applies. Check our repairs@
    Thanks will do
    Paul
