Ariston AWD12 Washer Drier…
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Ariston AWD12 Washer Drier…
  • #9871
    laurenceuk
    I am attending this machine tomorrow. The customer complains that it will not do a wash only prog but now always goes straight into the drying phase also. She says it is 3 years old so I am assuming she understands the controls and has not left some button activated.
    Any hints would be appreciated
    Laurence
    #136433
    Dave_Conway
    Re: Ariston AWD12 Washer Drier…
    laurenceuk wrote:Any hints would be appreciated
    It’s an Indesit clone with EVO1 controls, it could be anything although it should in theory be flashing some error code 😕
    Best go along with an open mind on this one Laurence, I would 😕
    Stick to hearing the facts direct from your customer on site, then make a few “tut, tut, oh dear what have we here?” type expressions, (gets ’em cautious to what comes next)….then look at the pump. :rotfl:
    Most likely something is open circuit as they abort, dial clicks round and the blower fan comes on, you’ve read about it hundreds of times I know.
    “Poke an’ hope or leave it broke!” ….is what we say in the trade 😉
    #136435
    Tony_EMW
    Send it to us for test £4+vat (includes return first class post) – at least you will know if the board is ok. Tony http://www.emwelec.co.uk
    #136436
    DAR01
    I had a similar fault on a Ind WD12UK once, Flashed 13 times, turned out to be a wire broken off on one of the t/stats on the dryer heater housing.
    #136437
    laurenceuk
    Hi Folks.
    The customer had just moved in and even before I took the lid off the customer commented that she was annoyed as the removing people did not put on the transit brackets.
    When I took the lid off the problem showed itself immediately: the plug on the t/d timer potentiometer had been snapped off by the the t/d heater cowling hitting into it during removals.
    Thanks for the help especially the “Poke an’ hope or leave it broke!” I am gratefull that a gap in my diagnostic abilities has now been closed. 😆
    Laurence
