Ariston AWD12suk grommet
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Ariston AWD12suk grommet
  • #23515
    cornwell40
    :shake:
    Above the sump hose outlet on the tub, on this model is what looks like an aborted other sump hose outlet with a 3″ diameter grommet on it. Pray tell what holds this in place as I cant find anything at all in the base of the machine after an almighty flood (Economy 7 and Indesit don’t mix). Indespit changed the tub last year as it was badly creased from the outside!!!Customer has lost faith in them: engineer already had!!!
    What I’m after is a listing for whatever spring, jubilee or zip tie holds it in place.
    Ta
    Tony C
    #198413
    allround
    Re: Ariston AWD12suk grommet
    they are held on with a wire type jublee clip which is part of the sub kit supplied with replacement tank , dont think there listed seperate. although sub kit should be but it contains 2 blanking plugs , clip and door seal and retainer spring .If you get stuck let me know as i have plenty of them kicking around van.
