can anyone help me. I have a awd12s ariston and the dial started clicking around also a burning smell occured, i took it apart and found the circuit board had a section burnt out on it.would this be the fault or could something else caused this to happen. Also does anyone know where i can get parts for this model online.
Bear in mind the module alone is roughly £80 or so, given that another fault within the appliance may well have caused the fault I would recommend an engineer takes a look at it for you.
If you need help with this, please post your postcode or have a look in the directories for an independant repairer.
