I have a fault code showing but cannot find any reference in fault code
list the machine starts by pumping then starts to fill but after a few seconds goes back to pumping out and the number two light starts flashing there are four lights number two flashes can anyone help with info I have’nt started to look at machine yet as it is a new model that I am unfamilliar with I thought it would be best to find the fault code first.
Also does anyone know if this machine uses a pressure switch or a float switch arrengement to determine water level.if so which side is float switch on?
Thanks Bassman
Had a very similar fault, not filling, was the heater.
Any strange faults on this range its worth checking first as it aborts the programme during fill and outputs a no fill fault code.
Cheers
Graeme
