HI, this is my first post, sorry to ask a question.
My Ariston AS100 will not fill with water, and the water inlet pipes are not trapped etc.
Help!!!
Thanks x
Mechanical timer control machine, so no codes for this one. Assuming that the water is on, the inlet valve has probably failed. If tested, the coil should read approx 3.5kOhms when split from the circuit.
