Ariston DOV317/1 main oven door hinge. P/N C00152867 needed
Home Forums Public Support Forums Spare Parts Help Ariston DOV317/1 main oven door hinge. P/N C00152867 needed
  • #40949
    fingery
    Hi guys,
    As title i’m after a door hinge for the main oven of an Ariston DOV317/1. I believe the part number is C00152867.
    The last thing i need is to spend 800quid on a new double oven to stick the Turkey in just before Christmas 😡
    Any help appreciated. I’d settle for anything at the moment…it doesnt have to be new, one canibalised from a spares unit would do if that’s all that’s available.
    Thanks,
    Chris
    #268161
    1brookie
    Fingery,
    Any luck? I’m in the same boat, so if you found someone with hinges and there’s one spare going, i’d appreciate a nod
    Part ref I have is: merloni door hinge ckr WE6300 – now obselete.
    1brookie
    #268162
    Re: Ariston DOV317/1 main oven door hinge. P/N C00152867 ne
    ckr WE6300 is not a genuine part number, it may be a pattern spare.
    C00152867 is a correct part number for door hinge and is listed as obsolete. 😥
    It was manufactured by Stoves so a possibilty a Stoves hinge would fit if you could find one.
    1brookie
    Jim,
    Thanks for feedback.
    On my cooker, oven & grill hinges are identical / interchangable.
    I’ve found ‘Ariston Grill Door Hinge for DOV317/1(WH)’ on espares:
    http://www.espares.co.uk/part/cookers-a … 317{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2f1(wh)/p/1092/491/0/861385/842652/grill-door-hinge.html
    It looks similar to the part i’m looking for:
    http://www.4ariston.co.uk/cgi-bin/produ … path=76561
    Any idea if this is a replacement?
    1brookie
    #268164
    It looks about the same, E spares are over the top on price most of the time but if they do have one hanging around then, ‘needs must’ .
    You may find that they have not updated that page and it is out of stock there as well.
    Nothing to lose really if the alternative is a new cooker.
    1brookie
    Jim,
    Thanks for that – I’ll give it a go and let you know.
    1Brookie
    #268166
    I’ve added it to the online shop and, they are considerably cheaper.
    No longer available.
    They are UK stocked so 48 hours normally for delivery all things running as they should.
    HTH
    1brookie
    Got part from espares: marked as C00156713, this is identical to the old/broken hinge and fits/works perfectly.
    #268168
    And, £6 more expensive. 😉
    1brookie
    Sorry ’bout that – I’d already ordered when you posted that you were stocking. Thanks anyway
    1brookie
