ariston evolution code f08
  • #8635
    machineman
    went to this m/c for fault code f08 which is heater relay related .switched on up came f08 stripped board down for dry joints/connections etc .tried m/c with board out of cover .all worked .put back together worked all weekend untill today then f08 any ideas or do you just change board and eeprom. M
    #129759
    machineman
    Re: ariston evolution code f08
    Sorry should be indesit.M
    #129760
    Dave_Conway
    Dodgy connection on the thermistor would be my bet M 😉
    #129761
    machineman
    tried that comes up with f03 if you disturb connections on thermister .went back there today switched on all ok could not get it to malfunction.m
    #129762
    AMS
    I’ve had this before. Recon board from EMW did the trick.
    andy2
    As most of these problems are due to burnt contacts from the amount of current the heater draws through them, have any of you lads ever considered changing the heater relay on the board, rather than the complete module. These relays are dirt cheap from places like CPC. All you need is a solder sucker and iron and it takes a few minutes to do. No doubt the customer will be well impressed with your expertise, and not to mention the cash you will save them.
    #129764
    jimbo2207
    I’ve come across this problem on EVO 2 equipped machines, in most of the ones I’ve dealt with, (if it’s an IDC machine, that is, thin wires to everything), the problem is usually down to wiring and crimp joints. On the non IDC (thick wires to everything), the problem is usually either the thermistor or a board fault.
