Ariston fault code?
  • #29509
    subs
    Model A1436
    When you put this machine on drain or spin it drains and starts to spin fine but then cuts out with the timer delay led and door lock led flashing. what does this mean? Ive checked all the normal stuff but cant find anything.
    Subs
    #223460
    Re: Ariston fault code?
    http://www.ukwhitegoods.co.uk/modules.p … c&start=30
    P3 – Indesit WIDL codes.
    subs
    Thanks Chris
    Subs 😀
    #223462
    subs
    From what i can decipher from the error codes for this machine, the first LED flashing along with door lock light is a F08 heater relay fault.Can anybody confirm this please.
    Much appreciated
    Subs
    #223463
    It is one of the most common failures on these machines, sadly not the easiest to resolve. In fact I do not attend any machines with the dreaded eight flashes complaint anymore, just not worth the aggro.
    If you use the search option and type in “Indesit AND eight AND flashes” in that exact format you will get several threads of reading material. :rolls:
