Ariston FB36(WH)GB – Everything works but the OVEN
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Ariston FB36(WH)GB – Everything works but the OVEN
  • #19894
    Oj-McSplodge
    The oven tripped the main fuse board when in use.
    After resetting the fuse board, the oven now does not heat up!!!!
    The oven light, fan and clock work fine.
    Have read some of the posts that suggest it is the Heating element.
    Could someone advice me what part I should get?
    Ariston FB36(WH)GB – Serial no:203110157
    Many thanks in advance….
    #184927
    Fan element is the probable cause. An email to spares@ukwhitegoods.co.uk will get you a price and availability.
    Should be in stock so would likely be sent Monday.
    Oj-McSplodge
    Re: Ariston FB36(WH)GB – Everything works but the OVEN
    Cheers kwatt…..
    And thanks to Lynchpin as well for there online help…
    Lets hope it is just the element.
    Fingers crossed.
    Thanks again
    #184929
    Dave_Conway
    Oj-McSplodge wrote:Cheers kwatt…..
    It’s the same person (Lynchpin and kwatt) 😆
    #184930
    Split personality? :duck:
    :p45:
    #184931
    Oj-McSplodge
    😀 Recieved the Fan Element as recommended by Lynchpin and Dave.
    Installed it in about 5 minutes (easier than I thought) and all working fine now.
    Checked the old element and found that it was all corroded and split.
    A BIG BIG THANKS to Lynchpin and Dave for all there help and support. You saved me a lot of money…..
    Cheers guys
    Jamie 😀 😀 😀 😀 😀
