Ariston Fridge Freezer MBA 3831V no longer freezing
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Ariston Fridge Freezer MBA 3831V no longer freezing
  • #39183
    CR
    Hi there,
    Defrosted the fridge freezer (not a frost free type) now the freezer won’t freeze fully.
    Fridge is fine but the three coloured lights were flashing, manual says this is excessive heating in the freezer.
    I tried several times to reset it over a few days but got it going on the last attempt, I’m now seeing if it stays cold overnight.
    Any ideas what it might be or how I can “cure” it?
    Though knowing Ariston it may mean a sledgehammer! :rolls:
    #261583
    helo_75
    could well be a weak compressor
    they do tend to run ok if its already frozen, but when u defrost, it struggles to reach the correct pressure
    see how you go on overnight
    #261584
    CR
    Re: Ariston Fridge Freezer MBA 3831V no longer freezing
    Thanks for the reply.
    Finally got it going, the freezer dial had actually broken, so while it seemed to turn it didn’t actually do anything. Pulled it out and used a screwdriver to turn the recessed dial to off and left it for a while.
    This seemed to work when I turned it back on!
