Ariston Fridge Freezer MBA 3842c UK Fridge Not Cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Ariston Fridge Freezer MBA 3842c UK Fridge Not Cooling
  • #45880
    steved20
    Please help, everything works fine except for the fridge, I installed a new computer module at the weekend and the fridge is still not cooling even on the lowest setting. Originaly it was not cooling and the light would always be on until the bulb blew. Since the new board has been in the light now switches off but does not cool in the fridge, any ideas, thanks in advance.
    #287494
    spimps
    Re: Ariston Fridge Freezer MBA 3842c UK Fridge Not Cooling
    Can you hear the motor/copressor running,black dome device at rear.
    Carefully check if it’s warm or hot.
    UNPLUG FIRST
    #287495
    steved20
    everything bar the fridge is working, the compressor comes on occassionally i suppose when it needs to, any ideas thanks in advance
    #287496
    spimps
    Is there any frost in the freezer,if so you could have a blocked evaporator so no cool air to fridge,if there is frost on the back panel inside the freezer it’s a sure sign.
    You could remove false back of freezer and defrost with hair dryer,no sharp objects allowed!! and switch off.There may be a specific cause but can sometimes it’s caused by door ajar overnight etc.
    UNPLUG first of course.
    #287497
    steved20
    there is quiet a bit of frost in the freezer, I will defrost it tonight and see it it comes back to life in the morning, it has always built of lot of frost up from new, do you know if this fridge has some sort of diverter on it, like when the compressor is not being used for the fridge its being used for the freezer?
    nice looking fridge pain in the arse though, again thanks for your help in advance
    #287498
    spimps
    There isn’t a valve on this one they aren’t fitted much now,all cheap and nasty!
    Cold air is blown up from the freezer through chanels in the rear wall of the unit so once it’s blocked with frost no air circulation.
    Will need 24 hours with freezer door open to defrost unless youhelp it with a hair dyer etc
    #287499
    steved20
    Where are these air ducts I have emptied the freezer and I cant see anything, regards
    steven
    #287500
    johnnyj
    If the Freezer is okay and the fridge is to warm it sounds like a thermistor problem which is not replaceable, there is however a timed control module part n/o C00262537 to overcome this problem, i have fitted a few of them and it works okay on most the time only one i had a problem with was a F/freezer in a big house it was situated in a annexe with no heating as the ambiant temp was low, and the module relied on time the fridge then started running to cold. Cheers JJ
    #287501
    spimps
    steved20 wrote:Where are these air ducts I have emptied the freezer and I cant see anything, regards
    steven
    OOps looks like I misled you on this one,I pictured it as a cold air blown up from the freeezer type but it obviously has an evaporator in the fridge.
    BG
    #287502
    steved20
    Where do you fit this part n/o C00262537 ?
    #287503
    steved20
    steved20 wrote:Where do you fit this part n/o C00262537 ?
    #287504
    steved20
    johnnyj wrote:If the Freezer is okay and the fridge is to warm it sounds like a thermistor problem which is not replaceable, there is however a timed control module part n/o C00262537 to overcome this problem, i have fitted a few of them and it works okay on most the time only one i had a problem with was a F/freezer in a big house it was situated in a annexe with no heating as the ambiant temp was low, and the module relied on time the fridge then started running to cold. Cheers JJ
    Hi there, where do you fit this part?
