My Ariston MBA 4033 Fridge Freezer seems to have died on me after just 16months. The socket, plug, fuse are all ok and double checked. I have tracked the power into the base of the unit (no broken cable) but there is no sign of life anywhere else. Is this likely to be an easy fix or will I need an expensive technician call-out?
Please help! 😕
SamuelJ wrote:Is this likely to be an easy fix or will I need a technician call-out?
The latter to be honest, this is an electronically controlled frost free unit which will require the correct test equipment to check the various components.
Check the repairs@ link below for an Independent in your area 🙂
