Ariston/Indesit LI62UK
  • #24136
    Seamy
    Got to look at one of these integrated machines, customer reports that when she selects any programme & starts is it does nothing but when she opens door, 3rd LED from LHS is flashing. Looked on Known Error Lists might this be thermistor & where is thermistor located? Cheers.
    #200817
    Fairdeal
    Re: Ariston/Indesit LI62UK
    If you take the two small black panels out from the front bottom, you will see the sensor in a brown,white holder connected upwards on to the body.
    You have to be careful though, as i did break quite a few of these holders.
    The other sensor is by the heater, if you take the left panel out it will be in the middle of the heater.
    Hope this helps
