Ariston LB12T UK
  • #19924
    RickT
    Have problem with pump operating on fill, as in anti-flood mode. Original fault was pump burnt out and shorting. Replaced pump. Machine now fills to first level, pressure switch clicks and activates pump. This repeats continuously. Have tried new pressure switch. Have visually checked the outer contacts on timer for welding. I’m almost sure it must be one of the internal contacts welded that are not visible and these are supplying the pump directly. Has anyone come across this fault.
    Rick
    #185039
    RickT
    Re: Ariston LB12T UK
    Has anyone any circuit diagrams for this model???
    Cheers Rick
    #185040
    Alanj
    Hi RickT,
    could be the p/switch internal connections. If you send me your e-mail address I’ll send you some info.
    Alanj.
