ARISTON LB12TUK HEATER BRACKET
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts ARISTON LB12TUK HEATER BRACKET
  • #9987
    mbdas
    HI AGAIN 😆
    I need the bracket which fit between the inner and outer drums it holds the wash element in place I also need the screw and washer for it have you got the part numbers, the only number Ive got is C00037177 is this correct ?if so have you got them and how much Electrue have no stock and number wont go in SEME
    thanks
    mark
    #137656
    Dave_Conway
    Re: ARISTON LB12TUK HEATER BRACKET
    C00037177 is correct for the heater bracket.
    C00037132 is the bolt and washer set, the nut is C00037135.
    I haven’t got any of them but Merloni will have no doubt, they have a minimum list price now, so they are £3.00 ex VAT each for the bolt and nut, the bracket is £3.91 ex VAT less any discount offered.
    #137657
    mbdas
    THANKS AGAIN
    MARK
    #137658
    mbdas
    HELP ❗
    Waited 10 days for part from hotpoint and its wrong 😥
    when I look up the part No for this model C00037177 comes up but its a long bracket the width of the element and the bracket I need is a small round one which the element pushes up to, is this a modification ❓
    thanks
    Mark
    #137659
    Dave_Conway
    The picture on Partfinder for this model shows it as being the normal type heater bracket 😕
    I just checked a couple of similar models that show what I think is what you need though, the heater sits over a stainless plate with a single central bracket that sits in between the two middle parts of the heater ….
    Part number C00058523
    I hope that’s the right one 😉
    #137660
    mbdas
    Thanks Dave,
    I posted Question and went to a Indesit W161 and this has the same bracket in it and when I looked up part no it is C00058523 🙂
    thanks
    Mark
