Ariston LD87uk
  • #22603
    clivejameson
    Can anyone provide me with the exploded diagram and parts list for the above machine please?
    #195586
    Re: Ariston LD87uk
    Possibly easier if you tell us what parts you are looking for Clive.
    clivejameson
    Re: Ariston LD87uk
    Thanks Jim, i’m after the part number for the NTC…connect or wolseley don’t list it….
    #195588
    Re: Ariston LD87uk
    I may be wrong, but I think the NTC comes with the control card 😕
    I seem to remember trying to find this for someone else a while back, not had to use one myself.
    If so then there are two different ones depending on serial number.
    Before 41119.0000 card is C00143207 cost £47.50 plus vat.
    After 41119.0001 it is C00111886 cost £16.00 plus vat.
    Some warning about not discarding the old card until you have verified that fault is cured. Apparently if there is an underlying fault the new card will not come of the factory test cycle and you will have to refit the old card to get it back to a ‘working fault mode’ how damned silly is that.
    clivejameson
    Re: Ariston LD87uk
    Thanks Jim….at this point i must cofess that i’d already procured the card so i’ve just peeked in the box and lo and behold….one NTC attached to the card! 😳
    Cheers for the help
