Re: Ariston LI 680 DUO Drainage Problem
Its a bog standard Indesit machine, very prone to pump blockages.
Remove the mains plug, place towels on floor, tip machine onto back or left hand side ( looking from front). Remove baseplate taking note of the position of the wires to the float switch before you pull them off. Follow the grey plastic hose into the machine to locate the drain pump. One small screw then twist and its off.
Take care to prevent any water dripping onto electrics and make sure the small black rubber O ring is in place when you refit.
