Ariston LI62 dishwasher fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ariston LI62 dishwasher fault
Viewing 15 posts - 1 through 15 (of 26 total)
  • #5950
    scullmeister
    I have a flashing light on the dishwasher it has 4 lights the first one is flashing and it does nothing?
    please help thank
    Al
    #114737
    Re: ariston LI62 dishwasher fault
    First thing to try is ‘Resetting’ the control panel. See your user instructions 😉
    scullmeister
    thanks but i have done that the thing resets, then when I select a cycle close the door and a beep is heard and the heavy cycle ligts keeps flashing
    thanks
    #114739
    Dave_Conway
    scullmeister wrote:the heavy cycle ligts keeps flashing
    Count the flashes, there should be a sequence to it with a pause in between.
    #114740
    scullmeister
    no it is continuous and I thought there would be too
    AAaghh
    #114741
    Dave_Conway
    It soulds like the control unit has gone to me 😥
    I would get an engineer out to check it though, although the “control card kit” as it is described is surprisingly reasonable at about £45
    #114742
    scullmeister
    ok now there are two flasing which ariston says is a drainage problem so i have taken all the water out and the cycle has started will let you know if it drains at the end if it doesnt does anyone know a good engineer in the Warrington area
    #114743
    scullmeister
    Ok just fills does nothing could it be the pump any need an egineer now any one help out in my area
    #114744
    lotusray
    hi if its first led of four flashing it indicates water has overflowed and is present in base
    r u using 3&1 tablets plus rinse aid?
    #114745
    scullmeister
    got past first led and emptied pan so now a drainage and pump problem i think
    if you start the cycle it fills no probs but that is it wont pump or nothing.
    then you reset the cycle it wont drain again the pump is needed i think
    This is a guess
    So again any engineers in the Warrington area
    #114746
    lotusray
    give me your numbe i know a lad who goes that far email me i will pass your details
    #114747
    scullmeister
    someone will be here today sorry needed somone asap as the missus is goin mad lol lazy had it to easy see
    But thanks for all your help
    Thank Al
    #114748
    Let us know what the problem was Al please 🙂
    merlino
    Am new to this, so sorry for clumsiness.
    My machine has same fault – does ‘water in the base’ mean where I can see it, or elsewhere? The pump seems to work OK, and there’s no water I can see inside, but it still stops after this part of the cycle. Same light on (heavy soil), same problem.
    If the control board is kaputt, where can I get a replacement from? Ariston want £90 to come out!
    #114750
    Dave_Conway
    Merlino (where did you get that name from BTW ?), I have to assume it’s the same model as the origiator of the threads ?
    Try tilting the machine over to one side slightly and see if any water runs out, with an old towel handy 😉
    The control unit is £41.34 inc VAT for your info, it may not be that that’s failed though.
    Take a look in the directories for an Independant repairer near you or pop your postcode here, we will certainly be a lot less expensive than Merloni and faster as well.
