Re: Ariston LI62 Dishwasher tripping electric
Heater, motor or water leaks in the base of the machine….all are common faults on these machines. You will need an insulation test meter to safely do this job. A standard multimeter will not do. Disconnecting components in a machine with an earth leak is not recommended as there is a danger of electric shock. Contact a local engineer or click the “Find an Engineer” banner below.
Please unplug the appliance. :plug:
