We are going to an integrated Ariston LI62UK dishwasher which is not heating, and showing an error code of 4th light (soak image) flashing. Filling to level, emptying and washing is all OK. It runs for about an hour before it stops (cold) and the error code shows.
Someone else (the customer) took it out, took the panels off, tipped it about a bit (?) and it then worked (heated OK) for a week, then stopped heating again, which is slightly puzzling. We thought it might be an underfilling problem, but it is filling OK. Could be dry joint on heater relay?
Any suggestions, and what is that error code?
Thanx guys.
