Home › Forums › Public Support Forums › International Forums › European Appliance Forum › Ariston LSE615 – Fault code: two LEDs blinking
- This topic has 6 replies, 3 voices, and was last updated 19 years, 8 months ago by
Chappers.
August 3, 2006 at 3:07 pm #19660
Chappers
ParticipantHi there,
Maybe someone can help identify what fault code this dishwasher is showing please?
It has four LEDs in a row, which pertain to the part of the cycle the machine is on. Before finishing the entire run, however, it’s reverting to constant flashing of the first two LEDs in unison. It seems like the contents have been cleaned, although I don’t think it had finished completely.
It seems to only have this problem when two certain programs are used: the first program on the dial, which is a 70 degree extended wash for stubbornly dirty dishes, and the second program which is a 50 degree “everyday” cycle.
I’ve Googled for it, but the only information referred to only one LED flashing at a time, and was for an older model.
Thank you,
JamesAugust 3, 2006 at 3:45 pm #183977Dave_Conway
ParticipantRe: Ariston LSE615 – Fault code: two LEDs blinking
That model number isn’t correct I’m afraid unless it’s a non-UK model ?
Normally the first 2 leds flashing is a drain fault though π
August 3, 2006 at 3:52 pm #183978Martin
Are you sure the model number is LSE615 as I can’t see a listing for that model? However many of the later ariston D/w’s with such an error code indicate that the heater is not working π
August 3, 2006 at 3:55 pm #183979Martin
:waving: Drain fault or heater fault?….That narrows it down a bit at least π
:waving:
August 3, 2006 at 3:56 pm #183980Dave_Conway
:waving:
August 3, 2006 at 5:34 pm #183981Chappers
Thanks for the replies. I’m sorry, I should have said that it’s a model purchased in Spain.
If it helps by giving an idea of the type of machine, as there’s perhaps a UK equivalent model, I can say that it’s around 4 years old. Starting from the left side of the top panel, it has on/off button, half-load button, 4 LEDs and then a rotary dial for selecting between roughly 7 programs.
August 3, 2006 at 6:49 pm #183982Martin
Chappers wrote: I’m sorry, I should have said that it’s a model purchased in Spain.
Nuestro consejo todavΓa se aplica en este caso! π
