ariston Lsi 61
  • #11479
    hilly
    control panel not responding there is power to the board but no lights show up apart from the on/off switch, I have replaced the board but still have this problem any ideas?
    thanks paul
    #145500
    Re: ariston Lsi 61
    This link has some connection to what may be the same problem? http://www.ukwhitegoods.co.uk/modules.p … pic&t=4175
    #145501
    Simon46
    Re: ariston Lsi 61
    Had one replaced board still would not work. Heater was gone as well.
    S.
    #145502
    Re: ariston Lsi 61
    You see, often these days these integrated circuit controlled machines ‘self check’ all the machines components without you realising it. 😯
    When they find something like the element being stuffed, they do not play ball and make it worse for the poor soul who’s trying to sort it by either not firing-up or giving some spurious error code that bears no relation to the actual fault at all 😕
    Check all the obvious things first before assuming the module is duff and let panic always be your last option 8)
    #145503
    hilly
    Re: ariston Lsi 61
    element is ok & ive done a insulation test all ok?
    help!!!!!!
    please, paul
