hi, machine starts ok,fills etc,works for a few minutes then just stops 😕 the programme light goes out,but the power light stays on.reset board, and the prog lights come on,then same happens again 😥 any help much appreciated.
I guess these m/cs are similar to the DWF types that HTPT use I would check heater or dispencer, also does the motor still turn over freely when the m/c stops?
regards Chris…
