Ariston LSV66 – Incomplete cycles
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Ariston LSV66 – Incomplete cycles
  • #32699
    Handy
    A number of problems arises:- I set a wash cycle it fills it begins to wash then just stops you can here the timer, the cycle knob automatically turn as expected and nothin no wash. If i manually turn the knob it will begin to wash again and then stop. Again manual intervention to continue cylce, the rinse cycle will start then stop. The dry cycle will start and not stop. Finally the washer will not empty. I cant understand how some things work and other wont. Thanx in advance
    #236083
    Re: Ariston LSV66 – Incomplete cycles
    No circulation, no heat and no drain, yes?
    I would think this is either a jiggered timer unit or broken wiring at the pivot point of the door.
    Power off if investigating.
    Drain pump motor replaced.
    Thanks for your custom 😀 .
