Ariston LV 62
  • #39296
    pcman
    Ariston LV 62 dishwasher fault code flashing pre wash light.
    when you switch on it starts to fill then just pumps out and the light flashing starts
    thanks
    #261958
    Re: Ariston LV 62
    1-4, L-R, which lamp is lit?
    pcman
    Re: Ariston LV 62
    first light or 1 from the left
    #261960
    Re: Ariston LV 62
    Flooded base, unplug, place a few towels on the floor and tilt the machine to one side. Mop up the water and try the machine again. If it fails in a similar fashion in a very short time you will have an internal leak that needs rectifying.
    If it works fine then it may have oversoaped, often caused by 3 in 1, 4 in 1 or 5 in 1 tablets.
    pcman
    Re: Ariston LV 62
    thanks iadom that worked will keep an eye on it to see if it is leaking
