Re: Ariston LV62 Integrated Dishwasher
The decor door and outer door panel will have to go in order for you to see what is going on. A lower seal kit is available – p/no C00056475 – an email to spares@ukwhitegoods.co.uk will get things moving for you.
You might like to check that the the inner door panel is flat at the bottom – I have had a spate of leaks on this family of machines where the inner panel has bowed into the machine, presumably due to the heat. Pushing it back down flat solved the problem.
Power off when working on the appliance.
