Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ariston magherita 2000
- This topic has 14 replies, 3 voices, and was last updated 21 years, 2 months ago by
admin.
January 15, 2005 at 8:01 pm #7499
KeymasterI have the above washer it runs for about 2 minutes on any program and then drains and the clock just keeps turning.When it is turning the on/off swith flashes twice and then long pause and then 2 again.I have cleaned the filter and checked all pipe work,it seems ok.Can anyone help me.
January 15, 2005 at 8:49 pm #123697Penguin45
ParticipantComputer is detecting a drive motor fault. Plenty of possibilities, probably engineer time.
Suggest you check Directories section for a UKW engineer in your area.
Penguin45.January 15, 2005 at 10:10 pm #123698admin
KeymasterRe: ariston magherita 2000
Thankyou for your answer,is there any thing i can do as i am an electrical engineer .Or will it require a new component.
January 15, 2005 at 10:22 pm #123699Penguin45
ParticipantPossible faults are motor brushes, motor itself, wiring and very often the computer board.
Pull the plug first………
Penguin45. :plug:
January 16, 2005 at 9:10 am #123700admin
Checked brushes and cleaned up comutator ,all wiring to and from motor look ok.How much are new circuit boards,if this is the fault?.
January 16, 2005 at 11:36 am #123701Penguin45
ParticipantOk, we’re getting down to specific parts now, so the model number will be required – Marhgerita 2000 is a generic. Check round the door opening or for a label on the back.
We can advise further then.
Penguin45.January 16, 2005 at 12:49 pm #123702admin
The only thing i can find is model no.a 1435 advantage and thats on the front of the unit.
January 16, 2005 at 12:58 pm #123703Dave_Conway
ParticipantRe: ariston magherita 2000
I think it’s an AI435 in that case, module is around the £90 mark and there are two different one’s fitted, it’s also one of the one’s that may also require a new EEPROM.
We will need the full spec on this machine (full model number and serial number) to be able to identify correctly(from the rating plate, possibly on the back).
January 16, 2005 at 2:19 pm #123704admin
The code on the back of the machine is A1435 uk.And the code on the circuit board is cod.215005377.07 0/05 s/w 1.32.I think its time to go and buy a new washer any recomendations.
January 16, 2005 at 5:06 pm #123705Penguin45
ParticipantI like Bosch………
P45.January 16, 2005 at 5:36 pm #123706admin
I have been out and bought a new washer,it is now working as i type.The job turned out to be a nightmare,thankyou for your advise.The only good thing to come out of it is that i fund 56 pence a washer and a belt buckle from the filter.Thanks again Balerman.
January 16, 2005 at 6:39 pm #123707Penguin45
ParticipantGo on, tell us what you bought!
January 16, 2005 at 7:17 pm #123708admin
I had already bought the washer before i got your message,but i bought a zanussi zwx 1605w it is very quiet and only cost me £300.Dont tell me they are no good or i will be back on here asking for advice again.All the best Balerman
January 16, 2005 at 7:21 pm #123709Penguin45
ParticipantNo, it’s a perfectly adequate machine – if you’ve got a vary spin option on the machine I’d back it off to 1200 and save the high spin for the bedding.
Good luck with it,
Penguin45.January 16, 2005 at 7:51 pm #123710admin
Now the washer is done you dont know anything about potterton boilers do you?
