ariston margarita a1635
  • #25658
    sandysuds
    hi guy,s can anyone help ,was at a ariston a1635 today the motor is fine in the spin cycle, but on a wash cycle it trys to turn ,but just turns slowly for a few turns then sticks,,i have checked ,motor carbons ,they are ok. could it be the control board,
    #206916
    I have had few times that mistake: more likely is motor time to change (try with other).
    Or: collector from motor is too dirty (carbon brush do not make contacts), wires, EPROM, PCB but more often is first one.
    Did you try it full loaded or empty?
    #206917
    sandysuds
    Re: ariston margarita a1635
    thank,s for your reply baron, i tried it empty
    #206918
    Does the motor make that “Ong” noise when energised? If it does, it’s finished.
    sandysuds
    THANKS FOR REPLY CHRIS, IT TURNS SLOWLEY A COUPLE OF TIMES THEN BUZZES
    #206920
    sandysuds
    thanks for all your help guy,s but im still nowhere, i sent the board away for testing ,no faults found ,tried a new motor still the same It fill,s up and the motor turns 3 or 4 times very weakly, and thats with the belt off,but it spins on the spin cycle .,i will give it one last try this week, HAS ANYONE ANY SUGGESTIONS
    #206921
    philfish
    Wild guess if motor ok and pcb ok pressure switch/chamber or heating element? ❓
    #206922
    Assuming that you verified PCB for dry joints related to motor relays, perhaps I would verify again wires from motor stator to PCB (more exactly on motor you have one coil with an middle point= three wires). Because on spinning use pole coil and middle point instead of washing when use entire stator coil. Verify also motor connector plug on PCB. 😉
    Other possibility is coming from: damaged EPROM and water level don’t force pressure switch to switch on full position (valve, triac or pressure switch). 😕
    It’s very important to know if he is finishing program without rotation on wash part?… 8)
    #206923
    Tony_EMW
    This sounds like the classic board fault – groggy wash but spin ok. Who tested the board ? Call us on 01159652118 if you want to try a module – I think this will sort it out ! Tony
    #206924
    sandysuds
    QER tested the module and said no fault was found ,it cost £25 .40.to find that out
    #206925
    QER eh? Oh dear that was pricey. 🙁
    Tony at EMW gives a far far better service and his pricing is a lot more realistic, even just to test the board. 😉
    #206926
    Tony_EMW
    We charge £5+vat to test any board and that includes first class return postage ! Send it to us – I am fairly sure the board will be at fault. You can reclaim the QER test fee. No disrespect to QER but I don’t think they have the full gear to test / repair these. Tony 0115 9652118
