Ariston margerhita awd12s pressure switch
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston margerhita awd12s pressure switch
  • #59756
    Lbutler
    Hi, im after a pressure switch forthe above, after exhausting the other options im sure it will be this. Im aware of the different types of switches so here is the serisl number and I will order through this site!
    206273233.
    Cheers Lee
    #339521
    odom
    Re: Ariston margerhita awd12s pressure switch
    This should be the part you need: –
    http://shop.ukwhitegoods.co.uk/Washing+ … witch.html
    but check the connector is right. Newer machines used a IDC (where the cables are together in a ribbon), which you need C00110327 for.
    Have you checked the old pressure switch with a multimeter to see if it’s opening and closing when you blow into it?
    #339522
    Lbutler
    I have pal yeah, there are 4 contacts and to be honest unsure whats what. Can hear clicking in/out when blowing, and all drain system i had out and fine?
